GREAT! Super excited about being an idiot..Now certainly you will. You need to remove the HH again. Make sure that the plunger button is there. Turn the engine until you have #1 cylinder in compression, align the damper marking and install the HH. Now the notch has to align with a valley right next to the scribed tooth. The scribed tooth will be to the right of the notch. Hopefully Gimpy reads this and checks for correctness. I learned this from him.
Yeah I have a third battery in the battery box. I cut the bumps down in the floor of the box and turned all my batts sideways so three fit side by side. I chose a seperate 12V system since I will prob be adding a good bit of 12V stuff. A converter will do just about anything that most will need. This was more of a preference than a any greater benefit.Maybe I missed it along the way, but did you add a sep battey for your 12v stuff. If so, where did you locate it? Is it better to do a dedicated 12v system? Or can you add a simple step-down converter? I guess it would depend on how much stuff you are running on the 12v...
Is the seller a member of SS? Where is the truck? I know of at least one person to stay away from down there. If you need help on the west coast of FLA send a PM to cessnatwin or pctrans. They may be able to provide info or help.
So here are some pics of the Deuce I won. Check out the crappy iphone pics and let me know if anything stands out that is FUBAR or a good ting. I know very little so just tell me what ya think.
Thanks
There are the 11.00x20 firestones somewhere areound 43"or so.What size are the Firestone Tires are on this Deuce?
