- 827
- 224
- 43
Hi All, I've been searching for info on replacing the rubber air hose that goes to my front axle air shift switch. It started leaking the other day, and can now be heard while the truck is running. Usually drains the tanks in about 15 min after turning off the engine.
Well I read here on SS, about some people had replaced the hose to their air gauge, using brass hose barbs, sliding new air hose over the barbed ends, and then using band/worm clamps on the hose.
Here is the thread that I'm referring to: http://www.steelsoldiers.com/deuce/31348-dm22630-how-fix-leaking-air-pressure-gauge-line.html
First: Is this reliable at 120 psi (which is what this truck is currently set at) ??
Second: Can I use this same method and replace the hose that goes to the front axle air shift switch?
Has anyone done this??
Thanks for any input!
