2012 vin info thread
CARNAC
The Envelope Please.
712
College Station, TX
Hello,
I have a 1962 M109A3
Manufacturer's serial NO. 053210529
Bought in 7500 Karlsruhe , Germany in june 8. 1993
Dealer Manfred Kraus
seller MSG W.K Myers , Chief, DRMO- Germersheim
Organization:123D SUPPORT BN CO D Location:ANDERSON BARRACKS
GM
Nomenclature:
TRUCK VAN SHOP Model:
M109A3 NSN:
2320000771636 Serial Number:
53210529 Registration Number:
4M81370 Year of Mfg:
1970
as of Dec 1987.
CARNAC
712
College Station, TX
My new M923 doesn't have its date of manufacturer stamped on its dataplates, which may have been replaced at time of overhaul. GL says it's a 1984 AM General truck, but I hope that you can verify that before I request my SF97.
a. Serial number C52306860
b. Registration number NL0J3C
c. NSN 2320010502084
d. GL via Barstow DRMO
e. No bumper numbers. Appears to be overhauled then not re-issued?
Thanks in advance!
Organization:USPFO ACTIVITY CALIFORNIA ARNG TRANS ACTIVITY CA Location:SAN LUIS OBISPO
CA
Nomenclature:
TRUCK CARGO D/S 5-TON Model:
M923 NSN:
2320010502084 Serial Number:
C52306860 Registration Number:
NL0J3C Year of Mfg:
1984 Manufacturer:
65909 Contract Number:
DAAE07-81-C-5597
Sep 2009 prior to this it was with the 55th Combat Support Company Material Management Center located at Camp Henry, Kansas.
CARNAC
712
College Station, TX
OK, here is my info from the ID tag and was inked on the drivers door + a shipping label on drivers vent. Name stenciled on windshield is: SSG Bauerlein . Truck is a 1971 M35a2 WOW
serial # 52532499
reg # 04L90171
NSN # 23200771616
Purchased from private owner in Chantilly, VA
Thanx in advance.
Organization:145TH ENGINEER COMPANY Location:CP ROBERTS
CA
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 NSN:
2320000771616 Serial Number:
52523499 Registration Number:
4L90171 Year of Mfg:
1971 Manufacturer:
65909
In Jan 1988 it was sent to the 286 QM Company in Bangor ME.
CARNAC
712
College Station, TX
Hey Carnac, could you see if you can run this? it is a 1986 M1035 Ambulance. A friend bought it and isn't on the site, I said I would ask for him.
a. Serial Number 011822
b. Registration Number 544016
c. NSN without dashes 2310011467194
d. friend bought it used car lot
e. no bumper numbers
Nope, no information.
CARNAC
712
College Station, TX
Carnac
I have a mystery for you if you can help. I have Trailer with and Incomplete VIN. It is a M870A1 Trailer
A Vin 1HZ2430xx10xxxxx
B Reg 108452
C NSN 2330012249245
D Red River Depot
E Not sure if Bumper Number 64CSG62E68E111T
Let me know if there is any thing else I can provide.
Thanks
Organization:68TH ENGINEER COMPANY Location:FT HOOD
TX
Nomenclature:
STRLR (LOW BED) Model:
M870A1 NSN:
2330012249245 Serial Number:
108452 Registration Number:
NX10X5 Year of Mfg:
1998 Manufacturer:
66788 Contract Number:
DAAE07-85-C-J042
Feb 2008
CARNAC
712
College Station, TX
Hello,
I have a mystery 5 ton. No info other than frame number, if you can get me some info that would be great! I'm told it's a 50's deuce but it has dual tanks and 5 ton axles. It's a 5 ton for sure
Serial is 952412925
That's all I have, thanks!
No info.
oddave715
Lexington, North Carolina
Thanks CARNAC!!!!
Hope this isn't too many vehicles.
I edited and added the second NSN number as the first is actualy FSN number and I read that the NSN number is the same but you add the two zeros in. I hope ths isn't confusing for you.
M715
a. 10065
b. 3F2703
c. 23209216365 or 2320009216365 (with the extra two 0s)
d. North Carolina dealer, was a lend lease fire dept truck from NC Forest Service
e. no bumper numbers available
M274A5
a. 282
b. 369757
c. 23209301976 or 2320009301976 (with the extra two 0s)
d. private individual in North Carolina
e. No bumper numbers or other visible markings
M416
a. 227
b. unknown
c. 23307065495 or 2330007065495 (with the extra two 0s)
M101A1
a. 340731
b. unknown
c. 23308986779 or 2330008986779 (with the extra two 0s)
d. north carolina dealer
jeffhuey1n
SMSgt, USAF (Ret.)
1,648
Laramie County, Wyoming
Oh wise and munificient CARNAC, I have a conundrum for you. My 1972 M35A2, which you have already identified to the 835th engineers, ND NG has a rather odd identification code underneath the last coat of paint applied by the 835th. The number/letter combination is a follows: WPIETO D0008. It is on the front bumper, the tailgate, both doors and on the left and right hand sides of the bed. What in the world did this one come from? Seems like it's the 8th one out of ?? but what...???
cx65083
wisconsin rapids, wi
I don't think the information provided is correct. There should be a different number on the drivers side front wheel well frame.
I found NO numbers stamped into the frame on the drivers side at all. Just that one number stamped into the frame on the passenger side. I think the second to last pic is the "bumper number", but not sure. I also have this faded scanner tag that they had JUST started using when I got out. I'll blow it up on the computer and see if I can make out the numbers. My eyes are not what they used to be.
jeffhuey1n
SMSgt, USAF (Ret.)
1,648
Semper Fi Marine! Looks like a Marine Corps truck to me. If it is, the 6 digit number is the truck BuNo or in plain English, it's Bureau Number. All equipment in my time in the Marine Corps had a six digit number. For example the BuNo on one of our CH-53A's was 153285. It's "bumper number" though that's not what we called them was MS 485. Both the stamped number and the painted number on the side of your truck are the same so I'm 99% sure that's what that number is. As to the other number M21580; at least I think that's what it says, is a unit assigned number. The BuNo never changes no matter what unit it is assigned to. The other number will change any time it gets permenantly assigned to different units. You'll have to do some digging but just a WAG says that truck belonged to the 21st Marines and it is truck number 580. Can't put any faith in that, I'm an Air Winger. That ground stuff was never in my sight picture (except on the live fire range) We just hauled them where ever they wanted to go.
Jeff Kyle
Cpl, USMC
1981-1985
MOS 6113/6167
CH-53A/D Crew Chief
Tweeter166
Banned
108
14
Montpelier Indiana
I got 3 trucks i hope you can decode for me. i bought them as 1997 and 1998 gov rebuild M813A1 5 tons wo/w but dont know ture year or MFG.. i was told NL reg numbers are AM Generals but i ant sure
a. Serial number C22810653
b. Registration number NL06V
c. NSN n/a
d. Indy GL
a. Serial number C32510136
b. Registration number NL08E
c. NSN n/a
d. Indy GL
has a Fed Num 23200508913
a. Serial number C22810955
b. Registration number NL0740
c. NSN n/a
d. Indy GL
has Fed Num 23200508913
Hooty481
Russell County Kentucky
1983 M915A1
a. Serial Number (VIN number) ------1UTSH6682ES002000
b. Registration Number -----also without dashes
c. NSN without dashes -----2320011252640
d. Where you bought it---- private seller
e. Bumper numbers if you can legibly read them ---- T-219X
thanks in advance
mbent1911
Thompsons Station TN 37179
1970 M813
a. Serial Number-- C12510193 (VIN number) -- 05G09170C12511915
c. NSN without dashes -- 2320000508890
d. Where you bought it---- GL COLUMBUS OH
HASSON1911
24
roseau/mn
1968 M35a2 w/w
A. ----- sorry no stamp on the frame
B. -----
C. 2320000771617
D. Private deal, but a data plate says it was part of a restoration program out of Ft. Knox
E. (ACX 4/16 CAV) (HHT 902)
Thanks, in advance CARNAC
cx65083
Jeff Kyle
Cpl, USMC
1981-1985
MOS 6113/6167
CH-53A/D Crew Chief
Thanks for the heads up. I did try some digging and found absolute JACK so far. A detective, I am not. Then I turned to my new digital camera! I turned it all the way up and took a few pics of the faded scanner tag on the bumper. After blowing it up and playing with the contrast on the computer I was able to pull a few numbers.
Oh great and mighty Carnac....or anyone else for that matter.... Do these numbers help or mean anything?
DTID: M215903167E196
NSN:2320000508842
This is the numbers I gave earlier:
Nat. Stock No. 2320000508954
Ord. Service No. 8736854
Id no. 565009 (I also found this number stamped in the frame)
Cont. No. M0002787c0022
I notice I came up with a different nsn number off the tag. They cant both be right can they?
N Arizona
San Antonio Texas
TX
Nomenclature:
M870A1 NSN:
NX10X5 Year of Mfg:
1998 Manufacturer:
DAAE07-85-C-J042
Feb 2008
CARNAC
Are you able to get the missing numbers from the VIN? I am trying to get the title with out doing a VIN reassignment with the DOT. Thanks for the help
chrisyoest
Claysville, PA
I recently bought a M813A1 5-ton cargo truck from GL.
a. Serial Number: C22810491
b. Registration Number: NL06QC
c. NSN without dashes: 2320000508913
d. Where you bought it: Government Liquidation at the Indianapolis site.
e. Bumper numbers: Not visible.
Thanks for your help.
reom35a2fluiter
Netherlands
I got also numbers of a other truck
Vehicle ---- M35a2c, w/o
a. Serial Number (VIN number) ------ 064010388
c. NSN without dashes ----- 23209260873
d. Where you bought it ---- from a civilian in France
e. Bumper numbers
Thanks in advance!
AIE1
Arlington, Virginia
Sir,
Researching a Fruehauf Trailer, Water Tank M107A1
a. Serial number: AV293952101394047
b. Registration number: ? Might be included in SN above?
c. NSN without dashes: 23308358633
d. Where you bought it: Civilian seller (Virginia)
e. Bumper numbers: 475GP HQ 3T
Additional info: trailer has a small data plate "Reconditioned ROSSFORD OD 9 1957"
Thanks in advance
