M35a2-3 Fuel Pump, Deal or no deal..?
DEAL OR NO DEAL....?
islandguydon
787
Michigan
I wanted an honest opinion on this fuel pump. I found a source for $50.00 each. There is a comparison picture to the standard pump. I like the bigger pick up area with the stainless steel mesh. Looks like a plug and play to me.
shenkmen
12
Lancaster, PA
I bought one as a backup.
Pics 1, 3 and 6 show a white button on the top of the pickup base. That is a filter (stainless steel mesh) bypass. If I use mine the bypass will be plugged and/or sealed. If my mesh get's clogged I don't want the junk to get through.
I'm unsure about what to do with the cut white wire which the seller states is a ground. Tomorrow I'll check for continuity between the two wire connectors on the top.
paulfarber
20
Gordon, PA
I have one.
Its not a perfect fit.. its about 1/4 inch smaller at the top.
Works fine, and other than having to make a 'filler' its a good pump.
Just be careful when you take the 24V connector off the old pump.... try not to bend the 'ears' that have to line up to keep in in place.
At $50 they are a steal.
islandguydon
787
Michigan
I have not done anything yet. Still waiting for shipment. Thats why I put it out there to see if anyone else got one of these and what the general consensus is..? Thats all.
m816
Chatham, NJ
We found a manufacture for the Military ones and the pump alone costs $200. So, Yes it looks like a good deal to me.
willy
Martinez, CA 94553
I have bought one from a company making these pump for the military for $50.00
so $200.00 is not a good deal
Willy
Oh well I made a mistake 50.00 is a ok deal
JasonS
202
Eastern SD
You can adapt the electical connector from the $50 pump to your old wire. Transfer the metal ring around rubber damper from the old pump to the new and it drops right in.
guns1977
27
AL
Well how is the pump holding up? Mine is getting weak on my deuce and need to think about getting one before I get stranded.
Thanks
Scar59
42
Mt. Eden, KY
Just double checking, this is pretty much a plug and play for the M35A2? I have one on a watch list.
JC
