LTWVARNG
- 2
- 18
So I outfitted my M1009 with all 33' tires now the 33' spare will not let the tailgate close all the way. I'm trying to see if anybody has already found a solution to this before i reinvent the wheel.
33" tires mounted on the tailgate is getting up there for weight! If you want the tire to swing out of the way BBBang has the best idea unless you fab something yourself. I dont like having the tires on the receiver as you cant open the tailgate without tire removal, and the front mount would block air flow to the radiator.I am in the same boat with the 33" tires. I am either going to buy or fabricate an outside spare tire carrier on the back, on the m1009 but I want it to swing to the side or drop down so I can use the tailgate. I added a receiver hitch and am going to use it as the basis for my tire carrier. I like this tiregate model but it is very pricy. TireGate Tailgate Tire Carrier
This one is a lot less, if you want to fabricate your own unit, should you choose to go this route.
Universal Hitch Mounted Spare Tire Carrier
Same here, a spare is a ummmm spare - Temporary. Your not going to hurt your CUCV running a smaller tire for a short distance.I have a 31'' spare and run 33s.![]()
Well I found the solution today. I had to have my friend push the tire forward closed the tailgait and then we locked it down. The lock plate thing is now off center but works fine. I will post some pictures of it later. I took the 1009 to the local airshow today.
No pics Maybe when I get home in 2-monthsAny Pics???
