GreggVA
- 4
- 8
- Chesapeake, VA
Did the Doghead Starter Relay Mod ![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
Starts nicely with it! I think glow plugs may be next! Little by little!
Dang, good landing! Too bad we didn't get a video so we could rate it. Just from the picture of the tracks, I'd say at least a 7.5!Drove it do the desert and went shooting. It does not like the Cajon pass. This thing is tough though! I was flying down a dirt road at about 65mph and saw the ditch to late to slow down enough. Entered the ditch at about 45-50 and caught some air on the other side. Ha ha. Nothing broken or damaged. You can see the point of landing in the pic. View attachment 336157View attachment 336158
I actually had video rolling at the time! But all you can see is the camera go flying. Ha ha.Dang, good landing! Too bad we didn't get a video so we could rate it. Just from the picture of the tracks, I'd say at least a 7.5!![]()
I don't know where the wife got the ultrasonic cleaner, she uses it to clean the jewelry (hope she does not find out I'd used itbaddy3, where did you get your ultrasonic cleaner? What % of WMO were you running and how long did you run it? How were you filtering it?
baddy3;1145534 I'll never run it on WMO again.[/QUOTE said:Why not? Are you saying the condition of the injectors was a result of running it on WMO? What did the injectors look like before running on WMO?
Yup, I'd had to remove a couple of injectors to extract swollen GPs and then the injectors looked OK. That was before I started running the truck on WMO mixture. Couple of months into using WMO the truck substantially lost the power, but having had problems with the clogging of IP return valve, I [FONT="]attributed [/FONT] that to the failing IP.Why not? Are you saying the condition of the injectors was a result of running it on WMO? What did the injectors look like before running on WMO?
It did. I could tell it was there in terms of acceleration, but braking didn't seem affected.I bet it rode nice with the weight!
I've had 3900 in mine before![]()
