Bobbing my M35A3
DeucesWild11
12
Putnam County, NY
Wow Steve, you are rocking and rolling on your bob project... I thought I had some tools.. I wish you were closer, I would love to hang around just to give you a hand and soak up some knowledge! I love fabrication!! :lol:
91W350
57
Salina, Kansas
I have been wondering how that truck was getting along, I would not recognize it now... Nice work, want to do an A2??? Glen
steve6x6x6
37
Winter Haven, florida
Hey Glen, this one has been more work than i expected. Mounted up some tires and installed new O rings , worked on the fuel inlet tube. Finished up the fuel system with a new sending unit. Getting close to setting the bed.
3dAngus
101
Perry, Ga.
That's a ton of springs after removing all that weight. What is the part number of the shocks you selected? Are they military or commercial?
steve6x6x6
37
We have been working on this thing some more. Welded the mounts on the bottom fo the bed. Setup a spindle and balanced the tires, the first one was perfect, the second one i had to add two counter weights and lug nuts.
Odyssey M
Colorado Springs, CO
Okay. That's even cooler. If I may ask, how much did that set you back? And, is this something that could be added to a steel frame post construction? Or, is this something that needs to be designed in to the structure during fabrication?
steve6x6x6
37
I designed the complete structure and made the drawings and gave them to a structure engineer and he copied it and put his stamp on the drawings and charged me $2,500.00. Took me four months to make all the beams and parts and my buddies help me bolt it togther, no touch and drill needed.
Odyssey M
I have a lot of respect for the guys that know how to work out problems (farm guys/techs) vs. the 'uber-educated' engineers who think they know how to build widgets. I am looking forward to completed pics.:grd:
phil2968
17
Lakeland, Florida
I'll give Steve props for being a 2.5 Rockwell Master. He may not know everything but he knows axles! He is also a fine fabricator from the looks of his spring mounts on this bobber.
I can't wait for a drag race! His A3 bobber against my A2 bobber!
Odyessy, where are you in Florida?
