epitts
- -1
- 18
- Terre Haute, Indiana
Got my 2A home, changed oil and fuel filters, cleaned fuel pumps. I am getting fuel all the way up to the injector pump inlet. I cracked the line on the front injector but am getting no fuel. Would the problem be the delivery valve stuck on the pump under the big hex nut? Unit was turned in servesable, look to have only sat for two years. Painted in 07 new fire bottle service in 2010. Fuel shut off is working, getting 30 psi oil on cranking engine.
Thanks for any help
Thanks for any help
If you are looking for a quick fix, regular hose clamps are fine. Use standard fuel hose you get from the local parts store.
