lawdog1623
- 1
- 0
- Texas
WOW! How cool that will be to see it drive out. You have to take video if it happens. Im subscribing! ![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
Plowboy,Targhee I'm new to the green iron as well so this is as much a question as a statement.
I see lots of "fire it up" responses but isn't it best to pre-lube cylinders, dump fuel/air/ oil systems, remove and replace filters, purge and prime fuel lines, clean da tank, get new fuel and a whole bunch of other things I know nothing about?
Just in case someone is reading through the thread 100 years from now and finds my
M135 sitting in the bush (well preserved because of Endura paint) I'd like them to know
"what is the best method to start an engine that has been sitting for a long period of time?".
I'm not saying any of the previous suggestions aren't good. It's just that your engine and I want to know what is best for us.![]()
Thats a nice camoflage job.
Amazing what a good cleaning does for the transformation from something found in the woods to "hey, it's a Deuce!".I made a little progress on Friday. Cut down some of the trees and I'm now able to open both doors! Strung together about 200 feet of garden hose, then hosed and shoveled about 40 years of junk and debris out of the cab. Did the same with extension cords and used the shop vac to get what was left. Can't get the power washer to it, so sprayed some Gunk on the engine and hosed it off, but that didn't do much to remove the crud on the engine.
Man is that the truth. I've walked past this truck for about 10 years. Never gave it much thought (couldn't see much of it). But now that I've laid my hands on it, cleaned it up a bit and started to think about the possiblities, it's really become important to me.Amazing what a good cleaning does for the transformation from something found in the woods to "hey, it's a Deuce!".
No snakes. Just wolves and grizzly bears . . .
Not too long ago a pack of wolves came into the farmyard a couple hundred yards from where the truck sits and killed one of the dogs.
This spring a mama griz and her two cubs were seen less than a mile away.
We always travel prepared . . .
Hey Jim, good to hear from you! Yes, we're familiar with that procedureOver on this side of the state, standard procedure is: S.S.S.
The Green Bug Has Set In, And The Hook Is set LOL, Good Luck Keep on PostingMan is that the truth. I've walked past this truck for about 10 years. Never gave it much thought (couldn't see much of it). But now that I've laid my hands on it, cleaned it up a bit and started to think about the possiblities, it's really become important to me.
Jack
