SUCCESS! my local tractor dealer (Gateway Tractor) has come through once again - they make up their own hydraulic hoses
took the cap off the aux fuel port on the gen and showed it to the parts guy - no problem. 4000psi pressure rated hose is so **** stiff, no way it collapses under the minor vacuum of a fuel pump and the fitting mates perfectly. i assume it is JIC, but it does seal, so i'm happy. @ $3.xx/ft, best know exactly how much you need though!
ahm
ahm
