LDS turbo on LD engine
tco3129
Flat Top W.V.
Have been searching with no luck for putting a turbo off a 5 ton on my LD M35A2.(Hope I didn't just overlook the thread) Has anyone done this? Will all the parts be available from the 5 ton? Will I have to swap the intake and exhaust manifolds? Don't know what series turbo it is but it is larger than my D turbo on my A2C LDT.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
Probably won't clear the starter. Exhaust will need mods too. Many 5 tons were retroes with deuce turbos. Might be happier in the long run selling it to a 5 ton guy. I have the parts to add a turbo to your LD (sans exhaust)
gimpyrobb
dumpsterlandingfromorbit!
27,791
785
Cincy Ohio
Someone on here just had a thread about putting a 5ton turbo on a deuce. Seemed it cleared everything fine, but the turbo was bad and he had to swap it out. No, you shouldn't have to swap the manifolds, but you might have to clock the starter so the blow off valve doesen't interfere with the starter solenoid.
tco3129
Flat Top W.V.
I had read that thread. I think his engine was an LDT to begin with so he may have already had many of the parts. I guess the best thing for me to do is climb up on the 5 ton with either a set of calipers and notepad or a handful of wrenches and a can of panther piss and start yanking parts.
gimpyrobb
27,791
785
Cincy Ohio
Basicly, all you will need is the intake horn to match the turbo's output, the different(turbo version) slobber tube, turbo(with gasket to manifold, oil supply tube, & oil drain tube), and the turbo exhaust. Let me know if you have trouble finding those parts, I might have some of them.
5,161
And you'll want to re-time the engine as the LD engines had a more advance timing. Unless you like popping head gaskets.
5,161
Actually it's retard the pump timing. The LD engines had more timing. Honestly you probably could get away with bumping it up to the middle or even top mark (LD). But I wouldn't want to load it down or tow another truck with it advanced that much. Timing affects cyl pressure as well. Too much timing = too much cyl pressure. Seems that given the head gaskets or rods are the weak link in these engines, one would give if you worked it hard enough. (IEL Beat it like a rented mule)
tco3129
Flat Top W.V.
The LD is in my bobber with stock 9.00x20 ndts. It runs smooth but lacks power. My M35a2c has the D turbo and will flat out pull the bobber on any and all the hills around here tho it weighs roughly 3500 lbs more. Thought adding the turbo from my 5 ton parts truck might help things. Both my trucks are daily drivers with the same fuel mix. The bobber gets me around but not nearly as well as the fullsize.
KaiserM109
SE Aurora, CO
The springs in the governor are different, too and the LDT has a “droop screw” that the LD doesn’t. You can just put in a allenhead machine screw. See the TM that you can download from this site.
I’ve been contemplating a change like that on my ’66 M109 if I don’t scrape up the change to just get a newer truck.
