Sephirothq
- 25
- 48
- Trevorton / PA
I recently got a 1977 mep005 generator on a trailer. I am in the process of trying to get it running. I have a copy of the TM's that i have reviewed but i am still having some questions.
When i got it all the fluids and the filters were drained / removed.
I put 2 gal of 15/40 W oil in the crankcase, 26 gal of diesel fuel in the tank and about filled the radiator with antifreeze.
On the inside panel it states 1 gal of hydraulic oil?? What are they talking about and where does it go?
I got the filters for it based off of other numbers i found here. IT seems my primary filter is just a metal screen and there is no way i can put the fuel filter that i got in there. Did some have a different primary fuel filter?
2 batteries later and it will crank and run on starting fluid with the battle short off. With it on I get nothing.
The fuel gauge does not work and i didn't have it running long enough to see if i makes power.
What i did find is the return line from the injectors to the injector pump is missing, gone, not there etc
And the fuel pumps don't work. I removed them, cleaned them and get nothing when power is applied to them . I ground the body and run a + to the wire. So i think they may be bad.
Why are there 2 in series? Is that necessary or just a backup?
From the other materials I have read it seems most likely that i will need to have the injection pump rebuilt and the injectors as well. Hopefully not. Any ideas on a source of the return line that i am missing or should i just get a piece of hose and clamp it on really good?
