robert c neth
Banned
- 233
- 1
- 0
- girard pa
what does it matter you know your right let them go on being ignorant.dont let other people get into your brain.
As someone who was a mechanic at a chevy store back then (and still is today with Acura). I dont believe the mechanics were "ill prepared to properly fix" these engines. I dont know if you have personnaly been inside a 350 diesel that has suffered catastrophic failure but as someone who has been I dont know how you can properly fix an engine that has had the crank blown into the oil pan. It was poor design. You cant take an engine designed for 8.5:1 compression and bump it to 18:1 compression without a major design change and expect it to work. Our way of properly fixing this problem was to put in a gas 350 replacement engine.Had GM incorporated a decent water separator and used better head bolting/gasketing, it would have fared far better. And like the VW diesels, mechanics were ill prepared to properly fix this engine.
Arguing with a fool is like mud wrestling with a pig......you both get dirty but only the pig enjoys it.Im sick of wasting my breath trying to explain myslef to somebody who says they know diesel engines.
6.2 was a clean-sheet diesel design from Detroit Diesel; no 'GM' truck input. Correct though that DD was a subsidiary division w/in GM hierarchy.Some facts. The Olds 350 diesel was produced from 78-85. The 6.2 entered production in the 82 model year. The 350 diesel blocks were always a diesel block but it shared nearly every dimension with the gassers and thats why it's called converted. The headbolt pattern was poorly suited for diesel compression and the chief cause of failure. The 6.2 was a GM design assisted by Detroit which was a wholly owned subsidiary at the time.
Fuel pump is the same bolt pattern and general external design and you use a 350 block off plate when adding an electric fuel pump on a 6.2L.The ONLY thing they share is bell housing bolt pattern.
Agreed, victim of my own wording. GM truck said they wanted a light duty diesel engine and DD did the rest. GM Truck did have some spec perameters such as retaining the standard bellhousing bolt pattern and such stuff like that. The design to fit within these perameters was all DD.6.2 was a clean-sheet diesel design from Detroit Diesel; no 'GM' truck input. Correct though that DD was a subsidiary division w/in GM hierarchy.
'Tanner'
True. I've got a diesel D19 Allis tractor and it shares the exact same block as the gas model. Only difference in these two instances is that they are a block built for a diesel but use the same block for the gas engine, not the other way around.The perkins diesel on my massey, uses the same block as the gasser. But it's only 60hp
This is true, and as far back as the 1960s, GM implemented a sort of parts bin manufacturing process. Manufacturing a small variety of parts for a large variety of models. GM had small block and big block engines, three six cylinder and one "iron duke" four, reducing cost and inventory big time. Ford on the other hand had a variety of V8 and 6cyl engines that had little or no parts interchangeability, every one was different in some way. GMC truck used V6 engines with displacements ranging from 305 cid to 478cid. one 637ci V8, and one V12 of 637cid. Why is any of this relevent to this thread? Anyone with GM engine knowledge, 20/20 vision and are able to fog a mirror can tell the diference between a gas and 6.2 diesel engine that shares no parts with any GM gasser.Makes sense to share parts when possible. Reduces inventory. Reduces cost. Hurts NOTHING. It's a no-brainer, really.
The Brigadiers were GMC. The Chevy equivalent was called the Bruin.all the tractors were Chevy Brigadiers.
Yup, you are right, They were Bruins. It was a long time ago, but I do recall working on some Brigadiers also. Like I said, they were all the same, guess I didn't notice it. That was a busy terminal.The Brigadiers were GMC. The Chevy equivalent was called the Bruin.![]()
