Navo
- 3
- 18
- Chesapeake, VA
I have a M35A3 and it has normal tags on it. Anyone have any info for the state inspection? Like what they are looking for etc?
Thanks
Thanks
All glass is good and the tires are no issue. Great....they are going to have to remove the wheels to check the brakes... Im sure they'll mess up the CTIS...ugh..They will check brake shoe wear, tire tread depth, if any glass is broken. That's about it.
HAHAHA! The tape was left onMaybe you can talk them in to just checking the parking brake shoes- they are exposed and easy. Also check the license plate light, I can't for the life of me remember if I removed the masking tape! It works though.
Under VA state law, they will pull one wheel per axle, their random choice which. So half of your wheels are coming off.
So, I dont have to look for a "special" inspection station (like for semi's)? I can take it to the one I get my normal car done at?It is under 20000LBS, so all inspections stations are required to inspect it.
Haha! Yea I figured I would be showing them how to "run" things. and I do have seatbelts, thanks USA!When I'd get my M151A2s inspected, I'd have to show the mechanics how to start the vehicle and how the light switch works.
From what they've told me, they inspect the vehicle for what it should have had on it from the factory for that model year. My original M151A2 was titled as a 1971 model and didn't require seatbelts (none were on there) but did require a rear license plate light (had to fab' one up). My current M151A2 is titled as a 1972 so not only do I need the rear license plate light, I also needed lap belts for all seats in the vehicle (had to add those).
Matt
