wrecker rope
Csm Davis
393
Hattiesburg, Mississippi
Yes I did search looked though lots of post but not what I want to know. What are the specs on the rope that is BII on the wreckers I have some and will not trust it as I have opened two nos packs and the ropes just fell apart.
Csm Davis
393
Yes thanks, but also the main one I was looking for is 1/2" I believe. But no worries if that 1&1/4" won't hold but 325lbs then maybe I should not have pulled so hard when I untied the 1/2", what would it's wll be 15lbs?
zebedee
conceptualizer at large
736
Central NY
Didn't see a 1/2" rope listed. Which wrecker are you working from? - These excerts were from the M816 TM.
Then there are the rope tackle blocks too....
zebedee
736
Central NY
Way too much idle time while I eat breakfast! :roll:
[I was expecting a curved line, as strength should be related to cross section area not diameter!]
Looks like your illusive 1/2 inch should be around 800 lbs. 8)
zebedee
736
Central NY
That would work for 1/2 "... Do you have the pulley blocks or do you just need rope? What's the price/availability (loctn and weight for shipping) on the Green Line?
zebedee
736
Central NY
Other rope?
Not sure if it helps, but I've bought climbing rope before - 1 million uses! Would be great with tackle blocks as it wouldn't untwist inder load.
Always loads on e-gay, even black, also some 2" manilla right now!
Csm Davis
393
Have also thought about the orange safety rope would be easy to keep up with! And I found some with a 9000lbs breaking strength, I would keep it in a repelling bag with my harness and carabiners so it can serve dual purposes, recovery and rescue.
zebedee
736
Central NY
For when you have to shimmey down the cliff to attatch the winch rope to the Hollywood star who just sent their Porsche into oblivion!
Csm Davis
393
Okay this is not an add I have some Manila rope for the wreckers if anybody wants it they have to promise me they will not use it for other than display it is rotten and will break but will look okay. Come get it.
Csm Davis
393
Okay guess the old rope goes on the fire. Anyone else use rope on their wrecker? Think I am going to get 300 feet to use for pulling my rear winch line out using the blocks I have and maybe a capstan winch.
zebedee
736
Central NY
I will be getting 300' of Manilla rope, just 'cause the BII says so. I have the two 1" pulley blocks though they don't appear to work as a pair (The single sheave doesn't have the thimble end - yet the double sheave does - should be the other way around inorder to get 4:1 pull or 3:1 with change of direction) ... I can't for the life of me see the purpose of the 1" setup in the BII, as it's lifting capacity is way beyond that which could be muscled by even a 2 man crew, with that said - alternatively why would you hook it to a vehicle when you have the real winches... Way more usefull would be a 1/2" or even a 3/8" pulley block setup.
On the other hand - use with a capstain would make sence - though I could see this if you only had a capstain instead of a pto drum winch(s)....
Any "Hotel 8's" who used an M816/M936 read this and want to chime in?.....................
