I was looking for some guidance on how to best wire up a push button for my glow plugs so that i can start this thing in the northern IL cold this winter. I've heard its not too hard and that I need to run 1 wire from switch to battery and the other from switch to solenoid so that I can hold it in longer to generate heat. I was also told I simply just need to remove the GP controller card located on the steering column in order to turn that function off. Also, I was told there was something else I needed to do in order to prevent use of 24v should the 12v not be available. Does this sound right? I was told the 24v would cause the GPs to potentially swell but that with just the 12v it would not happen.
If anyone knows of steps they used with a video and or pictures, a link would be great!
Thanks for the help! Just trying to get this thing ready for winter and new to the diesel world as well.
I was also told to change out the manual fuel pump with an electric one. Any help there would be great as well! mounting, location, wiring.
I was also told the fuel filters on these things are issues. Is there a mounting kit/fuel filter replacement that most people out there are using?
Thanks!
Justin (slik50)
Thanks!
Justin (slik50)
