What is this and what does it do?
stationjj
Middle Tennessee
I found this tube with a bolt in the end of it. It appears to connect left of the CDR valve under the air intake.
What does it go to? What should I do with it?
Picture below;
Thank You,
stationjj
doghead
4 Star General /Moderator
1,192
Follow it and see where it goes.
319
Lieutenant
3,347
58
Michigan
One thing for sure, you don't really need to use a grade 8 screw there, a grade 5 or even a 2 would suffice.
MarcusOReallyus
819
Virginia
No, it's the dilithium crystal drain. The flux capacitor hookup hose is next to the caripulation module, and it's always blue when it extends into this dimension. Something about its polarization modulus, I think.
Anyway, the dilithium crystal drain shouldn't be plugged like that. If your dilithium crystals can't drain, you risk unlinking the fenestrembulator.
Things get pretty ugly when that happens. :shock:
Keith_J
1,328
Schertz TX
Probably an axle vent line. Screw threads won't seal in a hose but it can plug. Vent plugging will cause eventual seal failure.
maddawg308
815
Appomattox, VA
Those are important, don't cap the line or remove the line, the axles need to breathe. Offroaders who go in a lot of water take those lines and semi-hardline them in so they aren't as flexible as rubber hose, and usually bring the line up on the firewall, then make a "U" in the line so the open end is pointed downwards a few inches. Unless you are under water up to the hose, you have positive breathing of your axle, and very limited chance any moisture will get in there.
Onestar
Leesburg, Virginia
I would guess diff housing vent line, mine were ran similarly. They make self venting plugs that arent supposed to let liquids in, mine already had these self venting plugs. I'm not sure where to get them but they can be worth it.
doghead
1,192
What would make you think anyone would reroute the axle vent to that location, and then plug it with a bolt?
cscmc1
Central IL
This thread got entertaining real fast! Seriously, though, OP -- you need to let us know where the other end of that hose goes. It's all just guessing until you do that.
muddobber40
la cygne, ks
Looks like the fuel supply line that would connect to the metal line running, or would normally run, to the fuel pump. Looks like from the picture there is an spin on filter and other lines running to it.
stationjj
Middle Tennessee
I am glad my post was entertaining.
I am new CUCV Mechanic. I am sorry I don't have the experience as a mechanic or working on CUCVs.
I am still trying understand how the CUCV operates.
I have had the CUCV for 6 months now. Yes, I am still learning. I ask that you please bear with
me as a newbie.
I do my research the best I can. Sometimes I do ask for verification, to make sure I understand something.
Currently I am tackling electrical issues. I posted this hoping someone with more knowledge than myself would know what it was.
Thank You,
stationjj
khandoh
Warner Robin, GA
But seriously, if that is a engine, transmission, or axle vent, just get a hose long enough to drape over the engine, or get a covered vent looks like (cant think of name, sue me. I'm a bit past driving legally...)
_____
|_| |_|
_| |_
|_ _|
|_ |
If this comes out.... (Should look like a 't' with a cap)
Edit: Hmm Ill leave that there in the case that it does look right, otherwise ASCII drawings are banjaxed on this site. I cant think of the valve's name, but go to your local parts house and describe the part I described.
Lieutenant
3,347
58
Michigan
me as a newbie.
Thank You,
stationjj
Highly entertaining, thanks. Your answer can be found in the 2nd post. Follow it to see where it goes and report back.
Part of learning is asking questions, another part of learning is doing.
