stranger75
- 0
- 6
- Nashville, TN
So, I changed out my belts today. Thanks to searching on here, I was able to do the power steering belt with out much issue. I then reconnected the batteries to start the truck and check my work. I was concerned I didn't put enough tension on the belts so I wanted to see/ hear them run. Turns out the Alt 2 (passenger side) was a little slack.
Without thinking, I grabbed my wrench and loosened the bolts on the alternator to make the adjustment. The batteries were still connected. The alternator slipped and the rear connection post touched a metal fuel line. It immediately started smoking and there was a little flame. There was also smoke up on the driver's side of the firewall at the terminal where all the fusible links are (forgive me for not recalling the name of said terminal).
I'm sure I burnt something up but I'm not sure what and I'm not sure where to start looking. If anyone could offer some insight that would be great.
If my description is a little vague I apologize. Let me know where I am lacking in details and I will try to fill them in, possibly with pictures if needed.
