paraclete comes
- 4
- 18
- southern ca
bummer wayne
Yea, cruzin down the highway and it just let go. Pricing rebuilt NP205s, Big bucks. I should have gone through it when I had the tranny rebuilt, a costly mistake .bummer wayne
Hea Marcus, the NP205 TC was not original to the truck. It was a 27 spline unit out of a 79 pickup and part of the 700R4 conversion so it was pretty old. The Off Road Design 205 is actually not bad at $895.00. I'll probably go with that. I've seen others at $1100.00. The Atlas unit goes for almost $2400.00, is more aimed for the rock crawler market, and is totally out of the question for me.LOL. I could convert to an NP208, but it's half the case the 205 is.Ouch, that's gonna leave a mark on your wallet!
4wd Low?Used my 1009 to pull my buddies non-op Deuce around his parking lot to allow for a trench to be dug.
With all those Grease Bushes down there that kit will help you all for sure!hauled the m101 to get tires with my buddies and than got a fantastic tire repair kit from 4 wheel parts! This kit is LEGIT, the robust handles are amazing. ARB Speedy Seal Tire Repair Kit (10000010) If dont already have this capability in the truck and travel the trails or just like to be self sufficient LOOK INTO THIS!
Keith_J, that set up looks cool. Can you break it down Barney style for electronics novices like me?
I presume this also means you have to be certain that whatever you are powering off this "second leg" is completely isolated from the chassis?Certainly. You know how houses have both 120 and 240? It is done by bringing 2 legs at 120 each into the house. From each leg to neutral is 120 volts, between the two legs is 240.
Well, that is how I viewed the CUCV 12/24 system, only instead of a neutral, it is at 12 volts over the chassis. This is why I have both legs protected with fuses and circuit breakers.
It is just a neat way of balancing the power. And because I didn't want to hack into the system, it is easily removed.
Yes, most are. The 12 volt accessory outlet I installed has two wires and a plastic body. The air conditioning evaporator-blower had both negative wires on the rear mounting stud, I pulled those off and connected them to the high side neutral, then checked to make sure there was no negative-ground connection.I presume this also means you have to be certain that whatever you are powering off this "second leg" is completely isolated from the chassis?
Today I installed some Rigid Industries lights. I got the 10" E-series spot/flood combo (pn: 11031).
If anyone wants more pics I can take em in the daylight tomorrow.
I took this last night. The video does not do these lights justice though. They are way brighter than they look in the video!Very nice.
I'd love to see a picture in the other direction. What the driver sees at night with and without the lights.
