TBob
- 1
- 0
- Harrison, Arkansas
I picked up a rough 1986 M1009, missing batteries, bad radiator, fuel tank removed, busted shroud. I've replaced the batteries, and pulled the radiator. I found an all aluminum radiator that looks like it will work. 3 row instead of 4 though.
1985 Chevrolet Blazer ALL ALUMINUM RADIATOR ALL35340X2098-3AA 6.2L V8 379 | All Aluminum Radiator | Chevrolet Auto Parts does this look like correct application? $188 beats $450 to recore mine, at least for now.
Just about to order the shroud and cover from Hillbilly, so that's set. Unfortunately he is out of original sending units, so I'll have to use a stock 3 port (without the siphon) to replace it. The previous owner said it was bad, but after reading, it may just have been a bad ground...he was kind of a poor mechanic, lol.
Might even be running by this weekend!
I have a couple other uestions on what a few things are, or were used for, like the spot on the front of the dash that looks like something was mounted there, and the 2 bars on the side behind the passenger seat. I'm thinking the dash was for a gps unit or something, and the white bars are bus bars for radio equipment?
Thanks, y'all have a great day!
