So if I've got this right, powering "camper" setup would be wired particular way on MEP-002a lugs running in 120v 1 ph mode to get all the capacity of MEP-002a (ie thru 30A cord 120v to camper)? Curious if this could handle running say 13,000 Btu A/C in camper (along with other uses in camper on 12v inverted power) for extended periods?
Then when MEP-002a needed to serve as whole house backup, it'd be wired differently on MEP-002a lugs and ran in 120/240v mode and feed house (ie with interlock or transfer switch) with proper sturdy cord with say pin & collar plug on house? This would "self balance" the MEP-002a so it could be loaded with whatever it could handle by just selecting breakers in house that were necessities (ie house breaker panel either interlocked or thru a transfer switch)?
Finally, in "stand-a-lone" mode where MEP-002a is by itself sitting out in yard/boonies (with it's own grounding rod) then it'd be ran in 120/240v 1 ph mode and best way to utilize in this method would be install electric breaker box that had various plugs to take advantage of both 120v and 240v . . . right?
Anyway to make the transitions from these 3 uses of MEP-002a as easy as possible?
P.S. Any benefit of newer 5 Kw unit like say MEP-802a over the old reliable MEP-002a? I'm torn between which genset best for me, but appears that MEP-802a's have enclosure so maybe quieter? Ground rod needed in setup for long periods of use with camper?
