DeucesWild11
Hello, so I finally got around to playing with my new to me MEP-002. I got two fresh new batteries, pulled the fuel tank to get re-lined. Then I cleaned the fuel strainer and replaced the two fuel filters. I also put in new rotella 15-40 with a new oil filter. I used a bucket of clean diesel fuel and placed the fuel lines in it. It's pulling new fuel out and returning the unused fuel back. After warming it with the glow plugs it just cranks but doesn't start.
I took off the two lines connected to the IP to see if fuel would squirt out. Nothing, I then checked the Stop solenoid and it was a bit sticky as the control arm did not move up when the plunger released it. I tried starting it with the control arm up but still no fuel coming out the IP.
Before I go about taking out the IP and messing with it, is there anything obvious that I am missing here that would prevent the IP from functioning properly?
Thanks guys!
Thanks guys!
