1-pin vs. 2-pin slave ports
1,156
I am adding a slave port to my dropside and updating my older truck to the NATO single pin style.
The cabs on all our trucks were designed for the older 2-pin setup and the cab side is embossed for that style.
All the single pin ports I have seen are the smaller style.
Questions:
1. Does a single pin slave port exist that has the larger, earlier style base?
2. If such a thing exists, does anyone have a source for a couple?
Recovry4x4
LLM/Member 785
1,824
GA Mountains
I have seen only adapter plates as in your one pic. One of the coolest mods I did to my deuce that's sold was to add one of the HMMWV slave kits that flooded the market a few years back. I drilled a hole under the right headlight and it fits there like it was made for it. Best of all the cables were just the right length to bolt both leads up to the starter hot and ground. Just check behind to make sure you get it where it needs to be. I much prefer a front or rear mount slave port.
1,156
I like it, really clever. But will it work for all the NATO slave cables? They fit inside that little crevice? I ran out of time today, trying to get 2 trucks ready, so I never had a chance to test it out.
I suspect we have the same kit-I bought 4 of them, one for the dumper, one for the other truck (since sold, replaced by dropside) and 2 for.......... I guess a DUKW and either a wrecker or maybe make the mule 24V.
I'm in the process of doing the same thing Clinto. I do have an adapter plate, do you need the dimensions?
Yes sir, please and thank you. I guess I'll have to see if I can get it close enough with the plasma cutter, otherwise I guess I'll have to have someone waterjet them for me.
Thankie
C
Recovry4x4
LLM/Member 785
1,824
GA Mountains
Clinto, I can take pics of it with both ends on it but not until Tuesday when I get off in the daylight. Working 15 today and tomorrow. As long as you drill it in the right place, they both fit quite nice. My deuce is gone but the first one I did was the M108 and its still here. It was my test subject.
steelandcanvas
87
Southwestern Idaho
Thankie
C
Here are my measurements, I used a machinist's scale, and sized the 4 mounting holes with drill bits. It should be fairly accurate. Anyone know where I can get a cap for a NATO single pin outlet?
1,156
Look what I saw today, courtesy of 3rdaavbncco. This is the adapter I need. Need at least 2, so I can add a slave port to the A2CV and one to HQ41, my '67 A2.
1,156
View attachment 404935View attachment 404936View attachment 404942View attachment 404947View attachment 404950View attachment 404952
I am currently using the adapter plate a friend of mine made (mucho thanks!) but I'd still like to have the "correct" factory unit. Does anyone have one of these aluminum adapters?
526
Winston-Salem, NC
I could cut these out of steel on CNC plasma if there is enough interest in them. Would probably cost $2-4 to ship one, but I could ship 10+ in a small flat-rate for ~$6. Price would probably be $10-$15 each.
1,156
Clinto were you able to use the measurements I provided? Were they accurate enough?
Yes and thank you. A friend of mine made me a plate that I am using in my '87 perfectly- My OCD is just causing me to stare at it every time I walk past it and I want the "correct" military adapter.
