goldneagle
- 1,018
- Slidell, LA
If you want to jb weld it...........give it a try..........my heater kit had a shut off valve that fit the lower hole anyway......I never used the top one, you might want to give that one a try first........but in the long haul I would change it out anyway.View attachment 402821
If I remember the intake/exhaust manifold gasket are one piece which means that you would have to remove the exhaust manifold to replace the gasket. There in lies another can of worms removing the exhaust manifold nuts from studs on the heads. Also the exhaust manifold is a multipiece assembly with sealing rings at the joints that could start to leak if you disassemble it. I usually don't like to use RTV in place of the correct gasket and ideally I would say replace it with a new gasket but in this case I would probably go with the ultra black hi temp RTV to seal the manifold. These engines have positive pressure in the intake manifold so the worst you might do is loose a very slight amount of boost but I would be surprised if you would see it on a boost gauge.Thanks to goldneagle a replacement intake is soon to be on its way.
I plan on reusing the turbo to intake gasket but what about the intake to head gasket, can it also be reused with some rtv or does it need to be replaced?
What about cutting the 2 sections of gaskets apart? If you place the intake manifold over the gasket and mark the edge, then cut the exhaust manifold gasket off?If I remember the intake/exhaust manifold gasket are one piece which means that you would have to remove the exhaust manifold to replace the gasket. There in lies another can of worms removing the exhaust manifold nuts from studs on the heads. Also the exhaust manifold is a multipiece assembly with sealing rings at the joints that could start to leak if you disassemble it. I usually don't like to use RTV in place of the correct gasket and ideally I would say replace it with a new gasket but in this case I would probably go with the ultra black hi temp RTV to seal the manifold. These engines have positive pressure in the intake manifold so the worst you might do is loose a very slight amount of boost but I would be surprised if you would see it on a boost gauge.
That was what I was going to suggest but then I figured I would be considered a . There is no reason at all that you couldn't do that. The way this gasket is made you would need to cut out the pieces for each intake runner.What about cutting the 2 sections of gaskets apart? If you place the intake manifold over the gasket and mark the edge, then cut the exhaust manifold gasket off?
Couldn't he also buy gasket material and cut his own gaskets? Especially if he does each intake separately? I would use gasket adhesive to the manifold. Once dry I would cut the openings in the intake holes and the bolt holes.That was what I was going to suggest but then I figured I would be considered a . There is no reason at all that you couldn't do that. The way this gasket is made you would need to cut out the pieces for each intake runner.
Thanks for the confirmation.That would be a even better idea. I am guessing that the stock gasket has a metal structure sandwiched in the middle because of it being used in the exhaust side that would make it a little harder to cut. It would be easy enough to cut the outside shape and like you said you could shellack the gasket in place on the manifold and then cut the runner out just like port matching.
