Powerstroke94
- 0
- 0
- Bowie, Tx
Alright guys, Im in the process if replacing the head gaskets on my truck, and when I went to get the nuts off of the studs under the injector ports I was only able to remove 3 of the nuts by themselves. The other 3 had to be removed with taking the stud out with the nut still on it. I finally got the nuts off of those 3 studs and now my question is, is there a special way you have to put the studs back in? Do you just hand tighten them then put the heads back on and torque them down or what? Thanks in advance guys!!
