You are correct.
Now the challenge is, to find out what is creating the draw. You don't need warm wires to have enough draw to kill the batteries overnight.
Here's a quick test you can do if you have a test light:
Disconnect the batteries. (Leave the ground in place.) Now connect a test light to the + terminal of the battery and the cable that should attach to it.
I'm betting it will light up. Maybe dimly, but it will light.
To find the problem, you are doing to have to start disconnecting circuits one at a time. When you get the right one, the test light will go out.
OR, you can use a voltmeter the same way. When you get the right circuit disconnected, the meter will go to 0 volts (or pretty close).
Hi all,
I'm having a similar problem with my M1009, and was hoping I could please get a little help. I'll try to keep this as short as possible: The day before Christmas, truck would not start, acted like batteries were low. Got batteries tested at Sears, they said both were bad, and they were 4 years old, so I didn't think much of it and bought 2 new batteries. I put them in, truck started up fine, got home (~70 mi away) for Christmas. Drove back down a couple nights later, and the truck wouldn't start the next morning - seemed like low batteries again. I checked with the voltmeter and had 12.7V on the back battery, and only 10.4V on the front. I suspected based on other threads here (
http://www.steelsoldiers.com/showthread.php?54292-CUCV-alternator-symptoms-diagnosis-and-fix) that maybe the driver's side alternator had a problem, so I took it apart and checked the diode and rectifier. They seemed fine, but I double-checked with a reputable shop, who also said they were fine. I put it all back together and hooked it up. With only the front negative battery terminal connected, I put a voltmeter between the disconnected front positive battery cable and the front positive battery terminal. I got 10.4V on the meter. I disconnected a few things, but nothing changed, until I unplugged the 2-prong plug that fits into the top of the driver's side alternator. Then, the voltage slowly started dropping from 10.4V to close to 0V. So, if the diode and rectifier are OK, could a bad regulator be a cause of parasitic drain? Or is there something else you guys recommend checking? Any help would be greatly appreciated.
