2013 VIN INFO Thread
CARNAC
The Envelope Please.
696
Corpus Christi, TX
Ok, my bad. I didnt put it in the correct format. All info was there. Dont worry about it.
I still don't think you get it. I do a bunch of these a week--without compensation. It still appears you haven't read post #1 so here is the specific point!
13. No photos of data plates unless specifically asked to take them and post them. I cut and past the information you put in here into a database search. I can't cut and paste from a photo. Remember this takes me time and I need to keep the amount of time I spend on this to a minimal. VIN numbers should all run together 0123456789, so don't use spaces or dashes. It just slows me down.
Rebar
St. Louis/Missouri
Carnac,
Thanks for the information above on the M817. You put the date "May 2008" after the info. Is that when it was refurbished or last info update??
Thank you very much. Donation today--would have even if you hadn't found the info because you have picked a totally righteous cause.
Thanks.
Rebar
jwesley74
9
Englewood, FL
Organization:
2025TH TRANSPORTATION COMPANY
JACKSONVILLE G1
AL
Nomenclature:
TRUCK CARGO D/S 5-TON
Model:
M923
NSN:
2320010502084
Serial Number:
C52303254
Registration Number:
NL0DUD
Year of Mfg:
1984
Manufacturer:
65909
Contract Number:
DAAE07-81-C-5597
Info April 2012
Organization:
144TH TRANSPORTATION COMPANY
MARIANNA
FL
Nomenclature:
Model:
M925
NSN:
2320010478769
Serial Number:
C52500472
NL0ANZ
Year of Mfg:
1983
Manufacturer:
65909
Contract Number:
DAAE07-81-C-5597
Sep 2010
Thank you so much CARNAC! Donation is forthcoming! Thank you for your time vested looking this up for everyone.
367
Castalian Springs, TN
Carnac, i have one for you, when you get a chance....
a. Serial Number -----------------1G8ED18J2FF207647
b. Registration Number ----------NF0E7P
c. NSN without dashes ---- ------2320011232665
d. Where you bought it --------- Craigslist LA
e. Bumper numbers -------------- No Bumper Numbers
Model# CD10516
Date of MFR 7/85
Contract # DAAE0782C4060
buffalorunner
El Paso, TX
INFO AS FOLLOWS:
M931A2 WO/W
A. SERIAL NUMBER/VIN 3101440
b. N/A
c.
2320012300302
d.
Ft. Leonard Wood, MO 65473
e.Bumber numbers (RIGHT side) 4MEB/193DBSB (LEFT SIDE) A223
Really trying to find out the year of production for my SF97, any other info will be helpful as well.
Thank You
Paid2play
Las Vegas
deuce info
m35
serial #053913100
reg#
nsn# DAAE0670c0001
bought las vegas nv
bumper#
stock# 23200771617
has a winch/hard top
thank you very much for any info.
this was the las vegas metro police department search and rescue vehicle but has been sitting for years
messge80
kennewick wa
truck comand 3/4 ton 4x4 m 42
a 80250482
b none
c 27418358266
d washington state
e none
m37 wow
a 80250482
b none
c 27418358322
d washington state
e none
thanks
Oros35
Pittsburgh PA
AM General M813A1 5 Ton wo/w
a. Serial Number (VIN number) --- NL00CB72C13610529
c. NSN without dashes ----- 2320000508913
d. Where you bought it Indianapolis, IN
e. Bumper numbers if you can legibly read them N/A
Haven't picked the truck up yet so this is the best I can do for now.
Thanks!
majorhitt
Dallas Pa.
Hello Carnac With all your wisdom and what little help I can give could you, would you be so kind to help me with the following M37
A Serial Number (Vin Number) 80006959
B Registration Number no luck
C NSN 2320008358322 OR 2320008358323 I found two
D Where purchased Northeast Penna.
E Bumper numbers Left side 2828104 Right side B9 Another set layered in are, left 2828AVN Right side B18 or B14 I see two sets of numbers hard to see
F contract number 4778
Your help is appreciated thanks in advance.
CARNAC
696
Corpus Christi, TX
It appears that it was with D Co 1st squadron 104th CAV which is a unit that was/is with the 28th infantry division (PA ARNG). My recods show D company but yours shows B.
it is a 1951.
2320-00-835-8322 is the correct nsn
registration number (hood number) was 2407080
CARNAC
696
Corpus Christi, TX
Thanks!
Organization:
207TH ENGINEER COMPANY
HAZARD
KY
Nomenclature:
Model:
M813A1
NSN:
2320000508913
Serial Number:
C13610529
NL00QB
Year of Mfg:
1972
Oct 2008
CARNAC
696
Corpus Christi, TX
m35
serial #053913100
reg#
nsn# DAAE0670c0001
bought las vegas nv
bumper#
stock# 23200771617
Organization:
0122
WYQBAA
Nomenclature:
TRUCK CARGO 2-1/2T
Model:
M35A2 W/W
NSN:
2320000771617
Serial Number:
53913100
4K96871
Year of Mfg:
1967
Manufacturer:
65909
Sept 2005 info. Only a partial unit number and what looks like a unit code. You might be able to find out more by googling the unit code.
CARNAC
696
Corpus Christi, TX
Model# CD10516
Date of MFR 7/85
Organization:
HQ, 33D INFANTRY BRIGADE COMBAT TEAM
URBANA
IL
Nomenclature:
TRUCK UTILITY 3/4TON
Model:
M1009
NSN:
2320011232665
Serial Number:
J2FF207647
NF0E7P
Year of Mfg:
1985
Manufacturer:
93219
Contract Number:
DAAE07-82-C-4060
Nov 1987
CARNAC
696
Corpus Christi, TX
INFO AS FOLLOWS:
M931A2 WO/W
b. N/A
c.
2320012300302
d.
Thank You
Bumper numbers 4MEB is 4th Manuever Enhancement Brigade (meaning Engineers) 193rd Brigade Support Battalion, A Company vehicle admin number 223.
Organization:
193D SUPPORT BATTALION COMPANY A DISTRIBUTION
FT LEONARD WOOD
MO
Nomenclature:
TRUCK TRACTOR 5-TON
Model:
M931A2
NSN:
2320012300302
Serial Number:
3101440
NL0WVW
Year of Mfg:
1990
Manufacturer:
47457
Contract Number:
DAAE07-86-C-J111
March 2009.
You need to verify the frame at the earliest. There was also a straight M931 that was also found. It has a C in front of it. If they refurb'd the truck, you may have one brought up to A2 standards. That really doesn't matter for your SF97 or registration since it is now a A2.
