162tcat
- 48
- 28
- Washington
Are the heads, block, crank and rods the same in the LD, LDT and LDS engines?  I have a friend who is giving me an LD engine and I would like to rebuild it with LDS pistons as a backup for my LDS 465-1a.  I know the pistons, injection pump and injectors are different, I just want to make sure everything else is the same.  Also, if it makes a difference, the LD is from a m35 but will be going in my LDS equipped 5 ton.
One last question, how do you ID the "thick deck" blocks?
thanks!
thanks!
