johnray13
- 0
- 16
- Chantilly, Va
I know if the arm assembly separates from the ball joint (the 4th picture) that spring will pull the governor arm back towards the fan and the engine will go wide open (don't ask me how I know) I guess it could be possible that with the spring too high it is pulling the arm back allowing too much throttle.
If you bump the start knob, is the stop solenoid pulling in and releasing when you stop cranking?
And I'm curious how you were able to shut it down when it ran wide open today.
Awesome job on the refurb btw.
John
John
