cliffyp
- 3
- 18
- Brownsville, Texas
I have an annoying vibration right at idle that I've been trying to find. It sounds like its coming from the starter area. I crawled under the truck this evening to just start checking/tightening bolts. The butt end of the starter, pointing towards front of vehicle has a little bolt/stud sticking through a bracket. I went to tighten it and it just sheared right off. The following diagram doesn't label the bolt, but it is what nut(5) and washer(6) attach to.
![ImageUploadedByTapatalk1362018886.069906.jpg ImageUploadedByTapatalk1362018886.069906.jpg](https://www.steelsoldiers.com/data/attachments/284/284403-3f765f780f67fb1a1879be29a0756260.jpg)
Is this a bolt that is replaceable or is it a built in part of the starter body? Other than possibly vibrating, is running the truck going to be harmful to the starter without the support? Unfortunately it will be several days till I'll have time to do anything about it. The truck can sit if need be, but I'd rather drive it if its basically irrelevant.
Thanks for the support!
