RAYZER
- 59
- 48
- sanford/florida
Uh, that says LIFT HERE not CUT HEREWell, I'm committed now!View attachment 414693
Rayzer,After looking at your photos again of the clearance on your landing gear, I hope that I will have enough clearance when I go to pick mine up. I will have to post the clearance so others can consider this when considering buying one of these trailers for the M931/M932A2s in the future. Thanks for this information.
Very nice looking 931a2 you have there agazza! And m146 too! Jacking up the back of the trailer just might work, will super singles fit?Rayzer,
I picked up my M146 with the M931A2, and as you said the clearance is close. My M146 did not allow me to flip up the landing gear feet. The mudflaps have to be removed on the M931, and the feet will clear the edge of the tires on most turns. It is when you get into a unlevel surface that they slightly rub on the edge of the tire tread. The feet will be modified slightly to provide the clearance needed. Thanks for making me aware of this issue. Just need to do larger tires now on the trailer to level the trailer. Most likely super singles. Attached is the photo of the trailer and truck combo.
No worries maddawg, I have so far loged almost 2500 miles on this rig, and have had only one piece of crown molding pop loose.I'm a little worried - a semi-trailer isn't a house. A house is built and stays put. However a semi-trailer moves and hits bumps and yes, it FLEXES a little bit. I just hope after all the work you put into it, that you don't take it for a long ride one day, and end up finding boards and trimwork all pulled out of their nails, due to the trailer body flexing a bit during it's movement.
Went with the 6 gal suburban, pilot light ignition, might add an electric element.The water heater installation turned out great. Looks like an original install. Which brand/model did you go with.
