Awesome Possum
- 0
- 0
- Central Texas
Thanks! One more question: Does the vent have to act in only one direction, or can it act in both?Remote reservoir will act as a vent.
The OP is a Buddy of mine, I don't think there was ever a solution to the problem. Maybe bumping this back up may produce some results. His A4 is still in his backyard, when the weather improves we'll get after "Thing 2" again.Howdy, I have a M109A4 with the same problem. I was following the thread, but did not find a post on the fix to the problem. If you do not mind, if you did find the fix can you please share ? Thanks![]()
If you rebuilt the airpacks wouldn't they be like new units? What was wrong with them?I had the same issue with my former Air Force m35a2c, the brakes locked, leaving truck parked in the yard. The airpacks got rebuilt. no joy. After 6 weekends of brake work, bit the bullett. purchased 2 new air packs, installed them. Bled the system with fresh dot 5. all is fixed.
