- 4,319
- 3,210
- Fort Worth, Texas
The buzzer goes off upon flipping the power switch and it starts the engine just fine but no power is reaching the electric gauges, lights, or blinkers. Bulbs and gauges have tested good, batteries are topped off, and alternator is new (with a tested output). The wires have been traced with the diagram from the TM and repaired; the cluster was cut from the harness.
I'm at the point I'm thinking to replace the power toggle switch to help narrow down a solution. If the gauges were working I'd suspect the 3 way switch to be at fault. Any input to tracking down the gremlin would be appreciated.
