Any idea what this pump is for?
nmwildman013
9
Rio Rancho NM
I will try to get a picture tonight.
I bought a used multifuel engine in the crate a few months ago and finally got time to play with it today. One thing it has that I have not encountered before was a pump mounted in place of the access cover for the injector pump drive gear. Pump has three ports. One is an AN fitting and two smaller barbs that look like the low pressure side. Engine had a whistler turbo and everything else looks like my deuce engine. I don't now enough about 5 tons to guess if this was a 5 ton engine. Anybody know what this pump is for?
Recovry4x4
LLM/Member 785
1,807
GA Mountains
Power steering pump as used in the 5 tons. Are you sure its set up as a deuce? Sump in front?? Starter on drivers side??
gringeltaube
Staff Member
2,468
Montevideo/Uruguay
....... a pump mounted in place of the access cover for the injector pump drive gear. Pump has three ports. One is an AN fitting and two smaller barbs that look like the low pressure side.......................... Anybody know what this pump is for?
5ton PS-pump, as Recovry4x4 said. Lots of info & pics, plus some useful links, here...
G.
