Need help finding info. On my okeff'e and merrit generator
mijon
Fenton, MI.
[h=2][/h]
I'm looking to find out more information on my O'keffe and Merrit Generator/Phase Converter. I purchased the unit off of a government website thinking it was just a simple generator. When I took a look at the unit, after I bought it, I seen that it defiantly wasn't that. I've been told that its a Generator motor that's a phase converter that converts 3 phases of energy down to one. Or you can use all 3 phases of energy??? I really don't know where to start. I've tried looking up some information on the unit but I really didn't dig up anything. If anyone can help me with information, it would be greatly appreciated. My biggest questions are what exactly is it? How do I attempt to crank over the engine? And what can I use it for? I've listed information from the maker tag below. Thanks
O'keffe and Merrit Model # MG-15-400 Serial # 78,
Motor Generator Set PU-126/U
Motor Rating
25 hp motor
Rpm at Rated Load 1735
Frequency 60
3 phase, voltage 208, rated load amps 55 per line
Generator Rating
Y connection
120/208 volts
3 phase, 4 wire
43.5 Rated load Amps per line
Triangle connection
120 volts
1 phase, 2 wire
10 kw output
104 rated amps
mijon
Fenton, MI.
Thanks for the manual it defently helps me to wrap my head around the unit. I'm still wondering how much current I need to hook up to the generator and where to hook that current up to crank over the generator motor. The manual is a hard read black and white just like all manuals
319
Lieutenant
57
Michigan
Page 2-3 starts to describe the input connections. You need 60 cycle input to get 400 cycle output. What you have is a paper weight, unless you have a 400 cycle radar as referenced by storeman.
