Pictures would be nice....So today I was buttoning up the truck ready to head to the desert and I went to install the Drivers Side Rubber Inner Fender Well Rock Guard deal and there was a small conflict w/ it hitting the A/C compressor. I pulled the brackets that the Fender Well slips into and put in 4- 1" long spacers to give me some room. It worked but now one of the 2 brackets for the Fender Well just barely touches the steering shaft. I went and got some 3/4" 1/2" ands 1/8" spacers so I can experiment and shorten the spacers up down from 1" first to 3/4" then 5/8" then 1/2" if necessary. The hood closed w/ 1" spacers, a minor deal but I wanted to let others know about it so heads up... I will have some pics maybe next week. I want to hit the dirt roads! This will entail removing the rock guad for the steering box. I like it better w/o that thing anyways because there is a grease zert in there that gets neglected. I am sure it could be modified w/o much issue to go back on as well.
Sure, when I get some time I will pull the 1" spacers and shorten them up as much as possible and let everyone know what I did. I am betting a 3/4" spacer will do it... I also ground off the THICK PAINT on the inner rubber fender well tangs and they go in and come out a lot easier now.Pictures would be nice....
