- 2,011
- 73
- 48
- Orlando, FL
Hi y'all! I have a 1983 M1009 with about 80,000 miles that needs new front wheel bearings. I have never replaced the bearings on a 4WD GM before. I've searched SS far and wide. I read and printed out all the threads. I read the TM's and printed out pertinent procedures. I even printed off the procedures from the GM factory manuals for the civilian K5 Blazer.
I plan on replacing the following:
- front rotor/hubs
- inner bearings and seals
- outer seals
- brakes
- spindle bearings
- thinking about installing Warn 20990 lockouts to replace the OEM set
I plan on keeping it a long time. I want the truck to be as safe as possible - I carry precious cargo in it regularly (my wife and daughter). The truck stops straight so I know the calipers are in good shape. Is there anything else y'all recommend I check or replace as long as I have the hubs torn apart?
Thanks for the advice!!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- front rotor/hubs
- outer seals
- brakes
- spindle bearings
