Any tips on removing upper torque rods?
simp5782
Feo, Fuerte y Formal
9,338
Mason, TN
Glad it worked. I would of probably had a conniption fit and went and got my plasma cutter after the first hour or so.
searls84
Las Cruces, NM
Reviving an old thread here.... But how in the world did you get to the nuts for the upper torque rods!???? I spent most of the afternoon trying to figure it out how to get them off. Flexed the axle both ways but still can't get to it. I know I'm over thinking this, what's the trick?
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Couple people have said they removed the spring pack. I had to replace the u bolts last time I removed one. Not sure if there is enough room for a socket and breaker bar.
searls84
Las Cruces, NM
That's what I'm afraid of, having to replaced the u-bolts if I pull the spring pack. I'm going to attempt cutting down a socket to make it short enough to fit in between... Ill post my results and a pic..Thanks for the feed back!
searls84
Las Cruces, NM
It worked! I went down to Tractor Supply and bought a "cheap" $9, 1.5" socket and chopped about 3/4" off it, and bingo! Slid right in. Hopefully this will save the next guy from having to remove the spring pack!!
