GPW axle horrorshow
JGBallew
Paducah, Kentucky
Customer brought in his "new" jeep for some inspection and other work.
Found the following when I got under it.Photo1434.jpgPhoto1435.jpgPhoto1438.jpgPhoto1437.jpg
Someone welded (badly) the steering arm to the knuckle housing.
That "bolt" I'm holding was dropped in the hole, and is actually an oil pan drain plug.
there's other serious issues, but this was a jaw dropper.
rchalmers3
Half a mile from the Broad River
30
Irmo, South Carolina
That's standard practice down here in the jungle, but the drop in bolt is definitely over the top and the waste of a good bolt.
If the original problem is that the steering arm mounting threads are pulled out of the knuckles, then smoothing off the bubba welds and repairing them with new thread inserts will certainly be the ticket. No need for big ticket items...... yet!
Rick
JGBallew
Paducah, Kentucky
Sorry for the slow reply, had a death in the family, then blew out my "good" knee.
I'm planning on lining up a serviceable axle, (Thanks for the offer Bazookajoe, I'll keep you in mind!) then tearing into the one on the vehicle to asess the damage. What I'm expecting is more of the same chicanery, but inside.
Yes, one weld is broken, one is "sound", (considering it looks like a typical "Chickenturd" done by someone abusing a stickwelder) so best case, I dress the gobs off, and rethread the studwells.
There is a lot that is just not right with this jeep, but considering it was used by a movie rental business, having it work for the camera took precedence over having it be right.
