Let's look at this:
I bypassed the resister on the fire wall.
The resistor pack has nothing to do with the charging system. It does control the glowplugs. If converting to 12v, this is needed
then I took both altenaters out and in stalled two 12 volt altenators.(just faster and alot easier than the rosinall convertion).
The CUCV alternators are 12v They just don't use the casing for the ground. You can use the CUCV alternator on just about anything if you add an extra ground wire. The Rosscommonequipment conversion is very simple. Remove wires, tape them up, install a new starter and your done. Did you remove the wire connecting the two systems together? If not I'm surprised that something didn't shortout. And why 2 alternators?
put a gear reduction 12 volt started in.
Okay, that is needed.
that is the down and dirty vertion of how to do it. I did that then moved on been 5 years NO electrical problems as of yet. now there are alot of other ways but that was fast and easy.
The OP needs complete instructions, not highlights.
to hook up the alts. I just hook them up just like they were and on the passinger side run an extra ground wire no promblem. you could even run just one altenater if you wanted to.
Again why use 2 alternators (purchase cost) when converting to 12v?
Think about your post. We have a newbie that doesn't understand electrical systems. You post some generic info without explanation. How does that help? It may even cause some issues as it increases that chance that he could hurt himself or his truck.
I am NOT discouraging you from posting, just asking that you give some more detail and try to explain what you are doing. Helps everyone learn something.
