cliffyp
- 4
- 18
- Brownsville, Texas
Throttle Valve cable bracket. You can still easily get the TV cable, but the bracket is very hard to find. The 700r4 is not electronically controlled, not is it vacuum controlled. The TV cable affects line pressure and shift points. It is very important to set it up correctly because an improper set up can burn up a 700r4 in a matter of minutes. There is a ton online about proper TV cable adjustment.What is the tv bracket?
