700r4 for my M1028???
cliffyp
Brownsville, Texas
What is the tv bracket?
Throttle Valve cable bracket. You can still easily get the TV cable, but the bracket is very hard to find. The 700r4 is not electronically controlled, not is it vacuum controlled. The TV cable affects line pressure and shift points. It is very important to set it up correctly because an improper set up can burn up a 700r4 in a matter of minutes. There is a ton online about proper TV cable adjustment.
Terracoma
15
Albuquerque, NM
The person selling it replied to my email and advised me that he has the tv bracket but broke a plastic piece on it???
There's no plastic on my bracket or the attached rod... Perhaps the seller broke the end/clip on the TV cable, rather than the bracket?
I'll let other 700R4 veterans confirm.
cliffyp
Brownsville, Texas
There is a little plastic bushing where the rod slides through the bracket, nothing else. I would image that he is referring to plastic clip on the end of the TV cable too.
Captain Caveman
Colorado
The only real drawback to the 700. As long as you use common sense and don't abuse it by overheating it, you'll be fine. It's a rock solid tranny.
