TNJMurray
We've got a part for that
- 69
- -3
- 6
- Dover/Delaware
We have five trucks that are like new that we are parting out . Let me know what you may need. What's the 411 on bumpin that engine up ? Tnjmurray.com. Murco@tnjmurray.com
Have you ever put it to the floor? or is it to the floor and all you can get it 40mphHi Guys, I have a 96 A3 and it is in great shape except for some surface rust. I drive it around town with insurance and all other things that make it legal to drive on the road. My truck only does 40 MPH @ 2600 RPM s and I hear a lot of other trucks doing 50 Plus on the hwy! What could be wrong, all my gauges read good numbers, motor runs great and trans seems to shift through all the gears. I need help! Thanks
No, I don't need to blow the motor, also I don't know the red line since mine don't have one. Please let me know. ThanksHave you ever put it to the floor? or is it to the floor and all you can get it 40mph
I will check that out, I have a GPS and I will try that. Thanks camp9Mine will do about 2850rpm's and do about 52 with stock tires. Now that I have the 395's I can get up to 55mph. There's a lot of debate as to how fast you can run the motor. You'll have to judge for your self on how fast you want to run it. Sounds to me that your right on for 2600, but best to get a gps and check it that way.
The piece on the front of the fan is an air powered clutch mechanism that unlocks the fan and lets it freewheel when the engine is cold and locks the fan to the hub if the engine reaches a certain temperature. According to the tech manual, if it freewheels with no air pressure to it there is a problem it should lock up until supplied with air.
