- 457
- 73
- 28
- Beaumont in SoCal
The TM quoted above is not available on the centralized page:Doghead, are you kidding me??? You think 90% of these guys know what a TM is?
http://www.steelsoldiers.com/showthread.php?77607-TM-s-for-the-Deuce
Or the empty threaded hole on the bottom of the bellhousing. But still, as a minimum everybody should be familiar with the Operator's Manual.I say give the guy some slack, at least he didn't ask about the bracket behind the exhaust like a lot do.
Although you're on the right track, you (probably) still have the wrong headboard.Thank you! Now I understand that it's not that I have the wrong headboard, it's that I'm missing a bracket (or two). I had a hunch that there should be some sort of bracket like that to hold the verticals in place. I don't see much value in having two of them as there appear to be in the pics; one at the top should suffice since the slots in the forward end of the bed can control movement down there. Is this bracket unique to C version trucks with drop sides?
I may take some careful measurements and fabricate a bracket like that, or perhaps see if a local guy or surplus outfit has a couple to send me (one right and left as it looks like each bracket holds 5 verticals.
Your truck looks VERY clean!
