I have searched and not found my answer . I have all lights but blinkers . I checked bulbs they are fine. I have checked ground to flasher unit,fine. I have one pin on flasher that has 26 volts and one pin on blinker switch with the same. I have no power to indicator bulb on switch. I have tried to jumper pins on switch but got no result. I know its either the relay or switch but don't want to just throw parts at it. Any way to test/diagnose before I buy parts. Thanks this is the last issue I have and will have a fully operational rig. Going slowly crazy here. Thanks Matt
