- 4,372
- 4,121
- Brentwood, Calif
Question....my 3rd axle's spring brake chamber has a bad diaphragm, I ordered a take off and what showed up was a spring brake chamber for axle no.2
the diff is there are only 2 air fittings on the #2 spring brake and the placement of the cage tool will be different then the one it is replacing.....the 3rd air fitting on the correct spring brake is capped off so that why I think I can use this chamber....can anyone chime in?
