WRMorrison
- 5
- 18
- Mesa, AZ
good one!I saw this on the tires; hope it doesn't mean they'll give up on me when I need 'em most...
-WRM
These look like MRAP wheels to me. There are many different styles of them both in aluminum and steel. I think I know of at least 6 different versions of the MRAP wheels now. Are you sure the center hole is 12.125-11.1875"? I'm going to guess they are 11.125-11.1875". Let me know if you need any adaptersThanks for the pic 'zilla; I appreciate it! I stopped by today to take a few more pics of the (apparently) MTVR wheels and tires:
View attachment 436210View attachment 436209View attachment 436208
In the last pic, I assume this is the date code? If I'm not mistaken, these tires were manufactured in the 51st week of 2009? I'm currently researching to find out what the backspacing is on these wheels so that I can compare them to the MRAP's (since I know they'll work for me with readily available adapters). If I can't find the info, I'll try and break one of these down to measure (NOT looking forward to that...).
I was able to pull a few numbers / stampings off the wheels also:
MFR 20076 (Titan Wheels)
05-15913
20x10.0
04 07 10
DOT "T"
MAX TIRE PRESSURE 105 PSI
Titan EW 03 01 10 S1
05 0949350
USA 20x10.0 312
The pilot diameter of the two halves also varied slightly. The outer section of the wheel had a pilot diameter of roughly 12.1875", and the inner section had a pilot diameter of roughly 12.125". The bolt pattern measured 13.1875". *all measurements were taken with tape measure and eyeball*
-WRM
No, they really do measure ~12.125-12.1875, but I'm sure the 10 hole bolt circle of the wheel is the same even though the pilot diameter is different.These look like MRAP wheels to me. There are many different styles of them both in aluminum and steel. I think I know of at least 6 different versions of the MRAP wheels now. Are you sure the center hole is 12.125-11.1875"? I'm going to guess they are 11.125-11.1875". Let me know if you need any adapters![]()
I stand corrected, its an eye teaser for me then. I figured a 12" pilot hole with a 13" hole pattern of 1" bolts would nearly overlap. You are correct in that the 10 hole pattern would match the mraps anyway if its: 10x -1" holes on 13.1875" diameter (to center of holes).No, they really do measure ~12.125-12.1875, but I'm sure the 10 hole bolt circle of the wheel is the same even though the pilot diameter is different.
-WRM
Once again...open mouth = insert foot. Not sure what I was thinking when I said it (and later swore by it...), but you're right; the pilot opening is closer to 11" and some change.I stand corrected, its an eye teaser for me then. I figured a 12" pilot hole with a 13" hole pattern of 1" bolts would nearly overlap. You are correct in that the 10 hole pattern would match the mraps anyway if its: 10x -1" holes on 13.1875" diameter (to center of holes).
I'm sure the wheels aren't probably offically called MRAP's, but that seems to be the most common vehicle they are put on that Im aware of. They are used on other vehicles, but I cant find many pictures at the moment. Even some PLS and other trailers have wheels with the same pilot hole and bolt pattern. In any event, I used to keep a pretty good eye on GL for the wheels to go up for auction. I've seen several different versions of the wheels with many different size tires. I'm sure some vehicle at some time had those wheels and tires on it. Below is a pic of a Vehicle Mounted Mine Detector VMMD HUSKY, they use these size rims with the CTIS. I'm not sure what size tires are on it, but they look large. I saw quite a few of these larger oddball (to me) tires with mrap wheels come up for auction out of Barstow CA.Once again...open mouth = insert foot. Not sure what I was thinking when I said it (and later swore by it...), but you're right; the pilot opening is closer to 11" and some change.![]()
I've got one wheel off the tire for measurement; it's sitting in my garage. Just by looking at the pictures of MRAP wheels online, they sure do appear to be identical (at least to my untrained eye), but how can you explain the mounted 16.00's? I highly doubt that the seller (who deals in MAJOR volumes of wheels and tires) would have mounted them (run-flats and all) just to make a little sale to me. Did MRAP's ever come with 16.00's? Do other vehicles use MRAP wheels?
I thought I had a bookmark somewhere about MRAP specs, but can't seem to find it at the moment. If I'm measuring the backspacing correctly (from outermost edge of the wheel to the mounting flange), the backspacing on my wheels is right at 11" flat.
-WRM
