ecomacgyver
- 0
- 0
- Los Angeles
Hello SS Members, First Post from a new member her. Thanks for all the great info on the site, loving my M1009 recently acquired. I've been going through some maintenance Items and one such item was a rear axle seal. I changed those out no problem but somehow my gov lock rotated enough that the spider gear alignment is off not allowing the center pin to go in. I have the tires with the axle on jack stands trying to rotate the pinion but no luck, the housing moves with the gears. In gear with the wheels while shifting, on the ground, the locker housing rotates.
Anyone have this issue and know how do I get the center pin in?
Thanks in advance for any help. picture is upside down but you can see that the center whole is covered most of the way by the spider gears
EcoMac
EcoMac
