scottmh
- 0
- 0
- Houma, LA (bottom uda boot)
Anyone carry a 20# C02 tank with them for emergency air tool use or filling tires in a pinch? I know its popular with off road guys
You can add a portable air pig as well. What are you doing to need to run air tools continuously? I've used the air to change 10 deuce tires with a 1" impact and a pig. I'm slightly familiar with the CO2 systems but curious how long the tank lasts running air tools continuously. I would think that running air tools continuously would deplete the tank fairly quick. Would you carry extra tanks?From what I was reading the OBA system doesn't have the volume needed to continually run air tools. You can do like Redbeard did or buy c02 tank and have instant air without having to wait. Some guys use nitrogen but I wouldn't because of the higher pressure it stores at.
I have personally used the oba system on my truck to swap out 11 9.00x20 tires to 11.00x20 tires at a steel soldiers rally... It consisted of using a 3/4" impact gun to remove 36 lug nuts, 24 lugs and a pneumatic bead breaker to break the beads on all 11 tires plus... Filling them up... The trucks oba system kept up just fine but it would be benefital to add a additional tank to up your volume of air in case of an emergency...From what I was reading the OBA system doesn't have the volume needed to continually run air tools. You can do like Redbeard did or buy c02 tank and have instant air without having to wait. Some guys use nitrogen but I wouldn't because of the higher pressure it stores at.
Those are fiberglassed wrapped ALUMINUM SCBA tanks. You'd have to know someone with access to a compressor to fill those. They are most likely 2216psi, but could be 4500psi.A buddy of mine is volunteer fire and he bought one of the fiberglass air tanks that they wear on their backs when they retired a bunch. They have some big compressor that pumps it up to a couple thousand psi! He got a regulator with it and retrofitted it to a air fitting so he can use it to reinflate tires when he comes off the beach. Told me that it will reinflate at least 10 oversized tires from 20 psi.
