100acre
- 16
- 18
- Bonners Ferry, Idaho
I had my mechanic put on some new belts and install a trans fluid cooler in my M1008. Before that it was running around 210* which is about normal I was told. He also put in a flex fan and fan spacer. He sistered the trans cooler up against the main radiator and now the temp maxes out. It says 250 but if the after market gauge could go higher I think it would. That's the other thing, of the 3 gauges now the oil one doesn't work and water temp gauge is higher than normal too. Is there a possibility that either the flex fan isn't blowing enough air or is the problem because of the two radiators are now sistered together? He also installed a steering column I got from another SS member. Now the turn signal I have to hold in both directions. It is also leaking power steering fluid. Main question is trans fluid overheating and why.
